Info on Vortec Heads
Old Jun 3, 2009 | 09:08 AM
JaggedJames24's Avatar
Car: 89' Camaro
Engine: 350 SBC
Transmission: Turbo 350
I found some Vortec Heads 10239906
The guy said and I quote
"The combustion chamber is 64cc from the factory. The shop that built these heads milled them down to 52 cc to increase the compression and horse power."
Is that a good thing ?
and do you think the heads are worth 400obo$
If I got them would I have to change anything on my motor other than the intake?
Thanks,
Old Jun 3, 2009 | 09:23 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Info on Vortec Heads
Actually, while GM claims 64, they're usually closer to 61cc. But 52cc is fine for a 305, on a 350 you'll need some Keith Black 22cc-dished pistons to run pump gas. And at that point, you'd be money ahead to buy some other heads instead.
Old Jun 3, 2009 | 07:05 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Nothing else will need to be changed. Accessory brackets will bolt up fine as well.
Old Jun 3, 2009 | 07:10 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
For 52cc chambers you're gonna need some massively dished pistons to be able to run pump gas. You also need a different intake manifold.
Old Jun 4, 2009 | 11:10 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If you do run them, you'll need to have the intake manifold machined because of how far the heads were milled.
Old Jun 4, 2009 | 11:24 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
This is something that doesn't get enough attention. Decking the block or milling the heads means the intake needs a trim too.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
