Cam info
Old Jun 3, 2009 | 10:54 AM
JaggedJames24's Avatar
Car: 89' Camaro
Engine: 350 SBC
Transmission: Turbo 350
Cam info
Im am wanting to put a cam in my 350 but need to know the biggest cam I can put in with out changing anything other then the cam Block Casting 14010207
Head Casting 462624
Thanks,
Old Jun 3, 2009 | 01:34 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Cam info
big cams seem fun, but need to be matched to your gearing. You can go ahead and install a huge,wild cam, but you may not like it. You didn't specify how much retainer-to-seal clearance you have, either. The cams I'm about to suggest are going to want at least a 3.23:1 axle, and high flow intake and exhaust systems, including headers. You might be able to get away with a COMP DualEnergy 275, it'll have a mean sounding idle, but it's about the most cam you can hope for within the limits you set, and it'll pull well up to 5500 rpm, at which point your heads are the problem. If you want more driveability, but still a big cam, look for a Crane MaxVelocity 272. The Comp specs as 275/277, 219/229, 110 at 106, .462/.482, while the Crane specs as 272/284, 216/228, 112 at 107, .454/.480. I'd go with Comp, because you can order it nitrided. Nitriding is well worth the extra cost. But with this much lift, you may end up needing some "plus fifty" locks, which are cheap, but then to have adequate seat pressure you may need some slightly stiffer springs.
Old Jun 3, 2009 | 01:35 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Cam info
Also, .482" lift is pushing your luck with older stock rocker arms.
junkcltr
Aug 2, 2019 11:12 PM
angel2794
Sep 8, 2015 06:22 PM
z28guy134
Sep 1, 2015 11:50 PM
camaro71633
Sep 1, 2015 10:24 AM
ambainb
Aug 29, 2015 12:43 AM
