1.6 roller rockers
Old Jun 6, 2009 | 02:04 PM
307s10's Avatar
1.6 roller rockers
i know there are alot of threads about this but seems to be that i have a diff proplem i went to put a full roller 1.6 on my motor and it seems the pushrods are to long the motor is a 305 tpi roller motor any one else have this proplem
Old Jun 6, 2009 | 05:03 PM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
Re: 1.6 roller rockers
Are you sure that the pushrods are properly seated in the lifters? What makes you think that the pushrods are too long?
Old Jun 6, 2009 | 05:16 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
you dont say what year the engine is. are they self aligning and are the heads set up for self aligning? did you mix and match the types? if they are center bolt heads did you get the thin rockers? a little more info may help.
Old Jun 6, 2009 | 05:44 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
http://www.circletrack.com/techartic...gth/index.html
Remove the rocker and check the result. The line where the ink has been worn away shows where the rocker's roller tip has contacted the top of the valve stem. It should be centered, but the line is a little too high here. That means the pushrod is too short.
Old Jun 6, 2009 | 07:05 PM
307s10's Avatar
i believe they are to long because with the valve closed the roller is almost off the valve stem to the header side they are self aligning i was told it was a 85 but the motor is center bolt valve covers and its a roller motor so the guy that i bought the motor from didnt know it was in his car which was a 85 camaro
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
