WFT no spark on #1 till higher rpm
Old Jun 6, 2009 | 05:59 PM
fozda's Avatar
WTF could be wrong now .. fasturn HSR 300+ign and coil . msd dist. new wires new plugs new ign module.. I went to check timing again just to be sure when idling 1# has no spark .. so i put a different wire on same thing .. clip timing light on #3 timing light light works great.. Now when i rev the engine to 2000 the dam #1 wire starts working.. Any ideas maybe a bad coil? or what else could it be??? Thanks
Old Jun 6, 2009 | 08:41 PM
Pocket's Avatar
Car: 91 Trans Am
Re: WFT no spark on #1 till higher rpm
The coil works or it doesnt. It cant narrow down one cyl to ignore
If the other cyls are firing correctly, check for a damaged cap/rotor
Old Jun 6, 2009 | 08:53 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Try clipping the pickup near the dist and see if it works. My POS timing light works like this.
Old Jun 6, 2009 | 09:01 PM
fozda's Avatar
Well fixed it i disconnected my 375+ add on and everything good now .. must have a bad controller
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
xxx3man`
Sep 23, 2015 10:37 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
