horsepower advice
Old Jun 7, 2009 | 02:13 PM
stones1's Avatar
Car: 84 z28
Axle/Gears: 373s
horsepower advice
i just got a 1984 z28 with a 350 it has a edelbrock rpm intake edelbrock 600 carb heddman hedders amd a comp 260 cam. the motor is tired and my goal is to get 350-400 rear wheel horse can someone please tell me what ile need to accomplish this
Old Jun 7, 2009 | 10:38 PM
g_port's Avatar
Car: 1984 camaro
Engine: 355 mild mods
Transmission: 700r4 bone stock
Axle/Gears: posi
Re: horsepower advice
sounds like a pretty good set up, good new is you should already be pretty close to your goal, because i have just about the same thing with around 230hp, i jsut need to get headers and intake and ill be set. what i would suggest doing is going with new heads, bigger carb, and a well tuned set up. be sure to do some home work on your transmission to. i heard if you get to much hp you will eat up the stock one.
Old Jun 7, 2009 | 10:49 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
What do you mean about tired? How many miles is currently on the engine/car? First thing I'd stay to do is make sure everything is running right and good (Firing on all cylinders, ext.) You want to make sure your getting all the stock horses before you try to add some aftermarket. After that then what g_port said would be the way to go. Good Luck!
Old Jun 8, 2009 | 01:52 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
400rwhp is close to 600 crank HP. Thats alot, especially for a small block. You'll need a MUCH bigger cam, alot bigger carb, and some top of the line aftermarket heads if you want to do this normally aspirated. Forced air is another option.
Old Jun 8, 2009 | 12:05 PM
stones1's Avatar
Car: 84 z28
Axle/Gears: 373s
thanks for the advice i found out the motor came out of a truck it has 100,000 miles on it and i just found out it has 305 heads on it what moron would do that no wonder its tired my first step is definetly some heads any suggestions on what i should get i was looking at the afr 205s or the edelbrock victor jr
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
