ALDL Datastream Issue
Old Jun 8, 2009 | 09:15 AM
tommyboy51300's Avatar
I just pulled my 89 Firebird GTA with a 5.7 TPI out of storage to start dumping money into it again. However, I know when I put it away I was getting a SES code 13 related to the O2 sensor. I made a ALDL cable to try to pin point the issue and I am having some trouble that I cannot find the answer to. I am using WINALDL software. When I connect the cable to the ALDL interface with a 10K resistor and I put the key in the run position I get all 25 streams of data which is what you would expect. However, soon as I start the car the data become erratic and I get between 1 and 5 streams of sensor data and not 25 streams of ALDL data. I researched this but was unable to find a solution. Does anyone know what I am doing wrong? I have also tried using TunerPro RT without any success as well.
Old Jun 8, 2009 | 10:24 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: ALDL Datastream Issue
Do you have a ground wire connection in your cable?
Old Jun 8, 2009 | 10:50 AM
Yes. I do have a ground wire. I made this cable
Old Jun 8, 2009 | 11:18 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Are you using a different computer this time? Maybe a USB to serial adapter? True RS-232 signaling is -12V (not GND but an honest to God -12V) for logical 1 and +12V for logical 0. Adapters like this can be hit or miss depending upon the particular serial port implementation. You could try playing with R2's value by lowering it a little, this should make it less sensitive to noise coming from the ALDL pin.
Old Jun 8, 2009 | 11:29 AM
I am using a different laptop than what I used before. I will see if I can obtain a different laptop and see if that works. I will report back tonight. Thanks for the advice.
Old Jun 8, 2009 | 12:17 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
It's a pretty common problem believe it or not. There are allot of obtuse applications for a serial interface like this.
MM2Robinson
Oct 1, 2017 09:16 AM
TheTraut88
Sep 11, 2015 05:16 AM
greenyone
Sep 8, 2015 08:41 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Gunsbee
Sep 7, 2015 07:10 PM
