Engine overheating
Old Jun 8, 2009 | 08:06 AM
ScorchedPaint's Avatar
Car: 1992 Camaro RS
Engine: Ls1
Axle/Gears: 4th gen 3:43
Engine overheating
Hi,
My 3.1L is overheating! I can drive it around for a while, but if I sit at a light or am in traffic sitting for a while it starts to overheat?! Its ok as long as I am moving. What is going on? Also, the cooling fan wont kick on unless I turn the air conditioning on! Anybody know what is going on?
Thanks!!
Old Jun 8, 2009 | 08:50 AM
racethesunlive's Avatar
Car: '92 Camaro
Re: Engine overheating
So your fan won't come on at all when idling? If your AC turns on then we know the fan and relay are working properly so it could be your sensor. This should be close to what you need.
http://www.autozone.com/autozone/cat...rchText=sensor
Old Jun 8, 2009 | 10:21 AM
Car: 1992 Camaro RS
Engine: Ls1
It wont come at all even when driving, unless i turn the AC on..... but thanks for the info I will see if that works!
Old Jun 8, 2009 | 01:51 PM
Car: 1992 Camaro RS
Engine: Ls1
well i tried the sensor but that wasnt it, seems the ground wire leading to the ecm is possibly faulty or the ecm iteself is faulty....... I guess i will just be turning the AC every now and then until the Lt1 comes in!
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
mustangman65_79
Sep 1, 2015 03:51 PM
jbd1969
Aug 17, 2015 07:06 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
