gas smell in oil
Old Jun 10, 2009 | 07:37 PM
cyko83's Avatar
Car: 83 trans am
Engine: 5.7 V8
Transmission: 700R
gas smell in oil
i have a problem with my motor. the oil keeps on smelling like gas but there is still a good amount of lube in the oil. i had the carb rebuilt but when it was getting rebuilt the guy told me that the edelbrock 600cfm carb couldn't be ajusted to a richer or leaner ratio. unless u do it with the two idler screws or the choke.
Old Jun 11, 2009 | 10:27 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: gas smell in oil
Wekk unfortunetly usually when you smell gas in the oil its a sign of bad piston rings. What happens is the pistons rings if they dont seal well when the fuel air mixture is ignited on the compression stroke the high pressures that result force gasses past the rings and contaminate the oil with "blow by gasses" causeing the oil to smell like gas. Thas can be confirmed with a compression check. Further more the edelbrock cars A/F ratio can be adjusted not only with the idle mixture screws but also by playing around with the jets and metering rods.
Old Jun 12, 2009 | 12:44 AM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
the guy rebuilding your carb said the mixture couldn't be adjusted?? i wouldn't trust the rebuild he did on it...
Old Jun 18, 2009 | 09:27 PM
cyko83's Avatar
Car: 83 trans am
Engine: 5.7 V8
Transmission: 700R
yea i was going to check the compression but i found metal shards in the oild so i have a bigger problem from the oil. but thanks for ur help
Old Jun 18, 2009 | 10:07 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
Just because your problem may be worse than what you suspected doesn't mean that these bunch of fellas still can't help you out. Believe me, they do.
Derick15
Sep 17, 2016 05:28 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Navy8125
Aug 21, 2015 09:32 AM
BurlyChev
Aug 16, 2015 09:08 PM
