Air/Fuel Gauge question
Old Jun 13, 2009 | 02:44 PM
WSX123's Avatar
Car: 1988 Trans Am GTA
I have a 88 GTA and installed a Air/Fuel Guage and all it seems to do is jump around from lean to normal to rich to normal to lean is that right is it supposed to do that.
Old Jun 13, 2009 | 04:52 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Re: Air/Fuel Gauge question
Well it will fluctuate a little bit, it should not be that drastic.
How does it measure it?
Lambda? if so how much fluctuation between 1.0
If it's off of the stoichiometric 14.7:1 how much fluctuation between that? I'm pretty sure our cars were designed to run lean for emission purposes so it probably would be closer to ~15
Old Jun 13, 2009 | 06:37 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
If you paid less than $250 for it, then it's working right and telling you almost nothing. A wideband would be ideal to show exactly the AFR rather than lean/norm/rich.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
