tps question....need help fast
Old Jun 14, 2009 | 02:00 PM
challenger71's Avatar
Car: 71 Challenger, 70 duster, 89 iroc,
Engine: hemi and 440
Transmission: a-833 4 speed
My 92 camaro with a 305 tbi and 5 speed starting having problems while running. The idle was fine, but when I would get up in rpm's the car would hesitate, backfire, and the tach needle was bouncing all over the place. I changed the tps sensor thingking that may be the problem, well now the engine is idling at 3000 rpm's and I can't get it down. Is there an adjustment I can do to get it right? Need help now as I am at work and have to be able to get home in the morning.
Old Jun 14, 2009 | 09:08 PM
Re: tps question....need help fast
thanks for all your help, I see I got a ton of replies
Old Jun 14, 2009 | 09:11 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
https://www.thirdgen.org/tpimod2
It's right off the main page...took all of 3 seconds to find.
Old Jun 14, 2009 | 09:16 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
It may be stuck open. I think I had to use a shim to keep mine from catching on the throttle bore side.
Old Jun 14, 2009 | 11:25 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
That's because we were all out on a nice saturday enjoying our rigs. The search button is your friend.
InfernalVortex
Apr 20, 2021 11:31 AM
Fred SS
Oct 12, 2015 11:27 AM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
