PCV Valve Open
Old Jun 14, 2009 | 03:36 PM
scarron's Avatar
Engine: 82 Pontiac 305
PCV Valve Open
I have a holley 650 and the pcv value has no hose hooked up to it. I take it that this is not good and should be hooked up. Should this run to the canister or to the valve cover? I already have vacums running to the valve cover so would have to buy something to splice it in if I have to run the pcv to it as well.
Old Jun 14, 2009 | 03:46 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: PCV Valve Open
PCV needs to be hooked up. Usually, the hose goes from the 3/8" fitting on the base of the carb or a fitting on the manifold, to the PCV valve.
New2Chevy
Sep 28, 2015 12:35 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
1985chevydude
Aug 20, 2015 12:29 AM
