distributor/oil pressure
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Quick question..
can a dizzy being off a few teeth affect oil pressure, even if it's seated all the way?
Transmission: 4L80E/4L80E
No. As long as the distributor is turning the oil pump shaft, where the rotor is pointed is irrelevant.
