Help with Igniton!!
Old Jun 17, 2009 | 12:30 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Help with Igniton!!
okay
so when i turn the ignition on my car..it rolls around and after about 2-3 second of trying to turn over. it finally does. but my main fear is that im going to be somewhere and try to start my car and it wont start...then im stuckk..any clue to why it is doing this??
~Mikey
Old Jun 17, 2009 | 10:54 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
CRANKY MOTOR
When you say “trying to turn over” that means the starter motor is not cranking the engine until 2-3 seconds after your turn the key.
But if you really meant “trying to fire” then:
You need to find out if you have a delay in the spark or fuel.
Use an ignition tester to find out if you’re getting spark as soon as you CRANK the engine.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look dorky. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
jimp2001
Feb 8, 2007 10:44 PM
ir0cz
Aug 19, 2002 10:30 AM
ir0cz
Aug 16, 2002 05:06 PM
PROCHARGED89Z
Jul 27, 2001 12:06 AM
