code 43
Old Jun 21, 2009 | 09:08 AM
ngonnelly's Avatar
Car: 1990 Camaro IROC-Z28
Engine: 5.7L 350cid
Transmission: auto
Axle/Gears: i think 3.42
code 43
i ran a scan tool and i came up with a code 43 wich is the esc and thats the eltronic spark control andim not sure what that is and waht i think the real problm is is that i have a 74 block and iv got no spot to put a knock senser so as of now i dont have a knock senser in my car any one know how to go about fixing this problm with my knock senser adn waht about the code 43 do i need a noew esc. i realy need help so far the thirdgen website has let me down no ones been answering my questions so if any ones got any thing to say to help me please help
Old Jun 21, 2009 | 11:03 AM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
Re: code 43
From the info that you actually gave, I could only assume that you need a block with a knock sensor or maybe to look for something that emulates the signal that the sensor sends. I'm not exactly sure if they're made or where to find one, but then again, I'm not sure why you're running something with such an old block, or what the setup of the motor is, displacement, etc. Sometimes the key to getting answers with people here is details and very clearly stating them. I dunno.
Old Jun 21, 2009 | 11:29 AM
ngonnelly's Avatar
Engine: 5.7L 350cid
Transmission: auto
Re: code 43
the block it self is 74 i rebulit the whole thing and its a 350 and i put a tpi ste up on it no im trying to find a hole to put the senser in i also read i can thread a hole in the fule pump blcok off plate and mount it there
Old Jun 21, 2009 | 11:31 AM
ngonnelly's Avatar
Engine: 5.7L 350cid
Transmission: auto
Re: code 43
adn if theres is any kind of by pass kid of thing for the knock senser
Old Jun 21, 2009 | 11:32 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: code 43
IIRC the knock sensor screws in where your block coolant drain plug is on your block on the passenger side above the starter . I hope that helps .
Old Jun 21, 2009 | 11:36 AM
ngonnelly's Avatar
Engine: 5.7L 350cid
Transmission: auto
Re: code 43
that is on the old 74 350
Old Jun 21, 2009 | 11:47 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Re: code 43
Yes remove a block drainplug and screw in the knock sensor .
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
