Burning oil
Old Jun 22, 2009 | 04:14 PM
mrmikesgta's Avatar
Car: 1989 Pontiac trans am
Engine: 305ci
Transmission: auto
Axle/Gears: not known
Burning oil
HI guys I wonder if anyone has any idea what to check for on my 305 tpi. The other day I removed the cat which is legal to do so in the UK and fitted a QTP electric cuttout in its place. But since doing so it has been burning oil and on an 200 mile run after doing an oil change it has gone from max on the dip stick to the add oil mark. I found It smokes very bad when I coast along with no throttle and when I hit the gas again it I get a big cloud of blue smoke and smells of oil. The car is an 1989 has 55,000 on the clock
Iam not sure if its anything to do with fitting the cutout or if its just a coincidence its happed at the same time.
cheers for your help
Old Jun 24, 2009 | 04:48 PM
louflemm's Avatar
Re: Burning oil
sounds like valve seals to me.
Old Jun 24, 2009 | 05:25 PM
mrmikesgta's Avatar
Engine: 305ci
Transmission: auto
Re: Burning oil
Cheers Yeah I have been thinking the same way, It has low miles but it still 20 years old and they didnt put very good seals in them.
Old Aug 13, 2009 | 05:08 AM
mrmikesgta's Avatar
Engine: 305ci
Transmission: auto
Re: Burning oil
Well valve stem seals all done with felpro seals now no smoke on start up but rev it hard and it smokes and smells of oil. Also if I take pcv valve out the rocker ist smokey but no smoke on the passenger side rocker. Any ideas?
Old Aug 13, 2009 | 05:39 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Re: Burning oil
burnt rings?
Old Aug 13, 2009 | 05:57 AM
mrmikesgta's Avatar
Engine: 305ci
Transmission: auto
Re: Burning oil
Originally Posted by Grumbles
burnt rings?
The car has only done 55,000 and didnt smoke when I got it under a year ago. No smoke at all on idle only when reved and on deceleration. So its looking like the engine is shot then ? Shame cuz it runs like a dream.
Old Aug 13, 2009 | 07:10 AM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Re: Burning oil
Pull the spark plugs, if there oily you've probably got some worn out valve guides.
Weak rings may cause for the plugs to be oily, but it's less likely.
You should also replace the pcv valve, probably won't do you much good but it won't hurt and its cheap to do.
Old Aug 13, 2009 | 11:53 AM
mrmikesgta's Avatar
Engine: 305ci
Transmission: auto
Re: Burning oil
I had all the plugs out when I done the valve seals and all are a very nice light golden color not black at all.Took it up to 120mph today and quite a bit of smoke from it at high speed but when driving round town no smoke, its sure got me guessing. What with the code 33 that wont go away Maybe its time to sell it out.
db057
Apr 28, 2019 07:45 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
my86bird
Oct 23, 2015 12:20 PM
CatmanFS
Sep 19, 2015 09:00 AM
