converted tbi to carb spark knock
Old Jun 25, 2009 | 11:35 AM
cm0788's Avatar
I have a 91 rs with a 87 305 engine. I switched over to carb and know i have a spark knock problem only when in gear and at high rpms. I adjusted the timing and it got a lot better but still have problems. the engine bogs down when the secondarys on the carb open. I dont know if i have to much fuel or to little. thanks
Chris
Old Jun 25, 2009 | 11:39 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: converted tbi to carb spark knock
What carb and distributor are you using? What's your base timing? What RPM does full advance kick in and how much advance is there?
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
db057
Aug 22, 2015 08:17 PM
gwade12
Aug 8, 2015 08:17 AM
