car wont start! :(
Old Jul 1, 2009 | 07:32 AM
Danus's Avatar
Car: 1989 305 RS Camaro
car wont start! :(
so last night turned up to my first cruise which i was reeeally excited about got there fine, at 8 o'clock when we were about to set off for a cruise, disaster! wouldnt start
very strange, the starter wouldnt turn, gave it a tap, put a spanner over it it would fire up but wouldny run
other things were no usual beep or fasten seatbelt lights when ignition is on
anyone faced this before?
cheers, Dane
Old Jul 1, 2009 | 11:12 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Re: car wont start! :(
When it did this was the 'SECURITY' light staying on? If so, you probably have a VATS issue.
Old Jul 1, 2009 | 01:57 PM
Danus's Avatar
umm im not sure, it was always on when the ignition is on
VATS? what does that mean?
Old Jul 2, 2009 | 03:01 AM
TiredRS's Avatar
Car: '91 Camaro RS
VATS- "Vehicle Anti-Theft System." Does your key have a black pellet in it? If it does, then you're vehicle is VATS equipped. First, what I would do is start checking fuses. I believe there is a 10A fuse labeled VATS. Check to see if it is blown, if so, replace it. Pertaining to the security light, put the key into the ignition and turn it to the on position. If the security light blinks and goes out, there should not be a problem with the VATS system. If this does not help, do a search for VATS related material. Other guys are more knowledgeable about diagnosing stuff than I am.
Thank God I'm not a doctor.....
Old Jul 2, 2009 | 06:15 AM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
What is a spanner?
Old Jul 2, 2009 | 01:56 PM
Danus's Avatar
wrench?
Old Aug 7, 2009 | 02:44 PM
BiggTrav's Avatar
Car: 92 zo3 z28
Engine: LT1 w/lt4 hotcam kit
Transmission: stage 3 700r4
Axle/Gears: posi 3.42
i had the same problem last year and it was the battery.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
