Port size matched to cam specs.
Old Jul 1, 2009 | 09:56 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Im trying to match my cam specs to the intake port size for a 388 with 10:1 compression
cam specs are:
Duration @ .050" lift:---> 240/246
Valve Lift: ---------------> .507/.510
Lobe-Center Angle:-----> 110
RPM Range: -------------> 2300-6500
I was thinking along the lines of 200cc intake port, aluminum heads with 64cc combustion chambers. This is going to be a strip/street car, Basically i want the most bang for my buck even if it means giving up road manners.
Thanks everyone!
Old Jul 2, 2009 | 12:43 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Port size matched to cam specs.
195-200 would be OK, but you could easily go bigger... that engine would probably really like a 215cc or 220cc head.
Old Jul 3, 2009 | 02:57 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I think an AFR 195 or a Dart Pro1 Platinum 200 would be the better bang for the buck, but since you're chasing peak HP, you'd get more with AFR 210 or Dart Pro1 Platinum 215s
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
80s Poncho
Aug 19, 2015 06:45 PM
355tpipickup
Aug 13, 2015 07:35 AM
knight72
Aug 10, 2015 09:32 PM
