Distributor placement??
Old Jul 2, 2009 | 10:44 AM
blazer29's Avatar
Car: 1991 Z28
Engine: 5.7
I have recently replaced my intake gaskets i have everything back together but cannot remember how to line up the distributor. i have the #1 cylinder at top dead center but am unsure where the rotor should be pointing when i set it back in. when i removed the cap with the wires i did not mark the #1 wire am i able to run the wires according to the firing order in a clockwise direction around the cap and have the distributor point at the #1 wire? any help would be greatly appreciated. i have a 91 z28 stock 305 Tpi.
Old Jul 2, 2009 | 12:18 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Distributor placement??
Correct. So long as the firing order is followed around the cap, #1 can be any of them.
But, if you want to be fairly accurate as to how it was stock:
Old Jul 2, 2009 | 12:37 PM
blazer29's Avatar
Car: 1991 Z28
Engine: 5.7
Thanks a lot that's just what i was looking for
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
