88 vert 305tpi flloods and wont start!
Old Jul 4, 2009 | 03:37 PM
ROCHEAD!'s Avatar
305 tpi, when cold it will start, ruff idle and when its hot it stalls out and wont start again. It floods. New cap and rotor, new gas. Had a code before we ran cleaner through the intake. let it sit for an hour and started up, blew the carbon out and the code was gone. Still, after i shut her down it won't start again. Fuel filter oil change and new spark plugs are now done. Im thinkin either fuel pump or coil. Ideas please.
Old Jul 4, 2009 | 09:12 PM
ROCHEAD!'s Avatar
Re: 88 vert 305tpi flloods and wont start!
I think they found the problem. While cold, they tried the spark and the spark was good. Started the car and let it run. They checked the spark again while hot and the spark was barely there so i think the coil is shot.
Old Jul 5, 2009 | 05:34 PM
Formula_Wolf's Avatar
Car: 1989 Firebird Formula
Engine: 305 Road Demon 525
Transmission: 700 R4
I had an ignition module do that to me. Thing would die on the road and once while I was pulling through traffic! Could have got tboned. That would be worth replacing while your at it. It usually sits right under the rotor.
Orr89RocZ
Apr 25, 2016 08:28 AM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Gumby
Members Camaros
Aug 21, 2015 12:50 PM
jbd1969
Aug 17, 2015 07:06 PM
