Carb Backfiring
Old Jul 4, 2009 | 08:30 PM
smoothjazz's Avatar
Carb Backfiring
Hi All,
A friend of mine who has a 83 z-28 305 motor just told me that his carb is backfiring.He mentioned that his first carb failed,and he replaced it with a Edelbrock 650.I told him its sounds like his tiiming is off.Any other ideas to through at him?
Old Jul 5, 2009 | 12:01 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Carb Backfiring
Timeing and a lean mixture are 2 common causes for back fireing in the intake. Ide like you suggested check the timing then look for vacuum leaks. Any particular time the back fire occures?
Old Jul 5, 2009 | 06:12 AM
smoothjazz's Avatar
Re: Carb Backfiring
he didnt tell me.i think its the carb he is using.he has the same year z-28 as mine(1983) and motor(305).he is trying to put a edelbrock carb on his car,and it wont work due to his dist is setup for a ccc carb.
2012sergen11
Oct 13, 2015 07:38 PM
85 Jimmy
Sep 30, 2015 07:56 AM
Damon
Sep 26, 2015 04:29 PM
lanceflame44
Sep 25, 2015 12:28 PM
RedLeader289
Sep 23, 2015 06:50 AM
