something is wrong
Old Jul 6, 2009 | 08:35 PM
Tubbed's Avatar
something is wrong
car died on me the other day. fixed a bad ground wire, but now the car will not rev. it starts and idles fine until i give it gas then it chugs out, let off the gas and its fine again. i can't even drive it. I tried another ecm and tps. Is there a way to test the map sensor? I have not checked the fuel pressure yet, need to borrow a tester for that. I'm thinking its a bad fuel pump. any ideas?
its a 88 305 tpi converted to SD
Old Jul 6, 2009 | 09:51 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Re: something is wrong
It sounds like your fuel pump is on its way out. Do a search you can find instructions on the forums for dropping the tank.
Old Jul 6, 2009 | 10:26 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Why does everyone jump all over the ECM first? They RARELY go bad. If I had a dollar for every ECM swap I've seen on this board, I'd have a brand new 2010 Camaro! And a TPS would throw a code, as well as a MAP sensor.
KISS - Keep It Simple Stupid! (I always have to remind myself to do this as well)
Try the fuel filter - they can get trash in them that settles, until you give it gas, then the trash gets caught in the flow and plugs the outlet, until you let off the gas again, when the trash settles. Much easier to try before dropping the fuel tank! Buy a $10 fuel guage and spend 5 minutes to put it in - everyone on this board should have one BEFORE anything else.
Keep your diagnosis basic and try the simple solutions first - 9 times out of 10 it's the little easy fixes that are needed.
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
