This is my first post in awhile, but it is that time to get working on the car again. First I have a 83 z28 with a 350 and th350 tranny. I have been working on the car for awhile and just recently replaced timing cover, new front brakes, as well as many other things. Last summer when I drove the car which was once or twice I always had a problem getting my tranny to shift right. First it was just a hassle to get it into gear then when I would be driving it would seem to only shift at woot. While I was under the car a few weeks ago I realilzed that my vacuum conection to the modulator on my tranny was not hooked up DUH! LOL. any way I got that back on and got the car back together and running but when I wen't to shift it it would not go into any gear at all. I figured I was still having a vacuum problem somewhere so I am having a problem with where all of the vacuum lines go on the car. I have 2 ports on the manifold behind the carburator and also the 2 on the front of the carb (edelbrock 1406). Right now I have vacuum lines 1 from the distributor, 1 from the metal line from the tranny, 1 that hooks to a t that was with the tranny that I had hooked to the other side of the carb, and also I have a line coming from the black cylinder on the drivers side and a long line coming down from the front of the car to a small canister that I am not sure what for. I am not sure I have all these lines hooked up right so any help would be apreciated......
I can get pics if you need a better idea of what I got but I did unhook the vacuum to the tranny from the T and tried hooking it to one of the manifold ports and now it seems to shift into gear just fine but I can't test it on the road yet...
If no one knows (as it seems), you can get this information from a factory service manual set. You may be able to order all of the books as a set, but if they are separate, be aware that there may be a separate electrical and vacuum manual or emissions and fuel manual (as well as a general service manual). Order those here: http://www.helminc.com
Or if you can get the exact name of a factory service manual, you can search google.com for that name in quotes. Sometimes used bookstores will have them sitting around. (Sometimes for quite cheap!)
On Probation
try cutting and pasting this into a new post in the transmission section. Or better yet, go back to a 700R-4
