No fuel to injectors 91 TBI
Old Jul 11, 2009 | 12:04 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
I have been having some difficulty geting my 91 RS with TBI started. I replaced the fuel pump relay and now I can hear my fuel pump prime. I am not getting ANY fuel to come out of the injectors. The car will start when I pour gas in the Throtle body and will run for about 4 seconds. I have done the following so far:
1) Replaced fuel pump relay
2) Checked Fuel Pump Fuse ( next to battery on passenger side fender) fuse looked good.
3) I checked both the injector fuses in the fuse box under the steering wheel both looked good
4) VATS seems ok and SES light is turning off
The fuel pump does prime for about 2 seconds when key is turned and then stops as it should. So I don't think the piump is bad. I am trying to eliminate things in order begining with the least difficult.
What should I check or tr next?
Old Jul 11, 2009 | 12:30 PM
Billy_Bob's Avatar
Car: 92 GMC Sierra 2500
Engine: 5.7l
Transmission: 4L70
Axle/Gears: GT4 3.73
Re: No fuel to injectors 91 TBI
Check *all* fuses.
How to check fuses...
http://www.dinosaurelectronics.com/Test_Fuse.htm
Old Jul 11, 2009 | 01:15 PM
THETANK's Avatar
Car: 91 rs
All fuses checked out at 0.01 Ohms. Checked both injectors both 1.5 ohms.
Old Jul 13, 2009 | 09:48 AM
THETANK's Avatar
Car: 91 rs
Any other suggestions still can't get it strated without pouring gas in the throtle body
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
