Motor mounts...
Old Jul 12, 2009 | 10:01 PM
Black Z28's Avatar
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
Motor mounts...
Ok its that time to do motor mounts in my car, its worring me with the way they look and when i rev the engine it likes to move a lot so its that time, plus i wanna do long tubes and i jus read it was easier to jus do this first. My questions are that, how easy are they to change out? how much work is it and is it a real head ache? my brother did his on his 2000 ss and it costed him a broken fingure and a 40 dollar light bar that he smashed cause he got agrivated and hes ase ceritifed. thanks for any help guys
Old Jul 13, 2009 | 12:13 AM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
Re: Motor mounts...
Well its not the easiest because the the bolts go into the k member and you have to get a wrench inside it on the nut, whats harder is getting the nut back on the bolt when you get the new mounts in place. Just make sure you have alot of time to work on it.
Old Jul 13, 2009 | 03:50 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
Re: Motor mounts...
and while you're at it, you might consider going to solid motor mounts. sorta like surround sound with all the shaking and vibration. after that, you don't need no stereo and certainly no subwoofer boom box.
took me a while to get used to it, and almost went to Energy Suspension Poly-U mounts (actually bought them), but the steel mount experience is too primal to forego.
Old Jul 13, 2009 | 03:16 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Motor mounts...
The experience of solid mounts really depends on if your engine is stock bottom end, or if you've had it balanced. And if you do go solid, still don't try a solid trans mount, go poly for that one.
Old Jul 13, 2009 | 11:12 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Re: Motor mounts...
well i got a poly tranny mount rite now in there and stock rubber motor mounts and my bottom end is externally balanced with a 400 crank set up in it
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
