help with smog and vacumm.. It was on fire
Old Jul 13, 2009 | 12:02 AM
tanugenfrugen's Avatar
i have a 86 firebird with a fairly stout 350 sb with a tpi system i removed the smog pump a few years back. the car caught fire on the way to the body shop and ive been trying to put it back together. any how the question i have is the egr solenoid fried and i want to know if i need it since the smog pump is gone and if i don't need it can i remove the egr completely and if so what do i do about the vacume routing?i also have the edlebrock intake and runners does anyone know what i gain from this
Old Jul 13, 2009 | 09:10 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: help with smog and vacumm.. It was on fire
You can remove it and plug the hoses. It will still run fine, but it may a little more prone to pinging. I assume you don't have emissions inspections, right? It will raise your NoX above legal limits.
jaridjohn
Oct 5, 2015 07:01 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
