backfire under acceleration
Old Jul 15, 2009 | 01:56 PM
92whiteta's Avatar
Car: 86 WS6 Firebird
Engine: 355
Axle/Gears: 2.73 open
i just finished my TPI to Carb swap and im having issues. the car starts fine but at idle i have a loud tick i cant tell where its coming from i dont think its mechanical. and when i accelerate the engine it backfires though the carb. not just a pop with smoke its a solid flame out the top of the carb and makes alot of poping noises the motor idles ok by itself it doesnt need help to stay running i think the backfire and the loud tick are from the same problem. they are in sinc the whole time.
thanks
Old Jul 15, 2009 | 02:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Start with the basics: timing, spark plug firing order, vacuum leaks, something that may have gotten into an intake valve (very likely given the symptoms).
If it is something caught in the intake valve, a compression test will identify the cylinder.
Old Jul 15, 2009 | 02:46 PM
92whiteta's Avatar
Engine: 355
Re: backfire under acceleration
i found the issue it is a roller rocker that is almost off. the problem is for some reason the push rod sits lower than the other pushrods. (way lower) low enough that i cant tighten the nut all the way down the pushrod and lifter are the same as the other 15 so i dont know what the issue is.i may have to replace the lifter i guess its not pumping up like it should. any other ideas?
Old Jul 16, 2009 | 12:13 AM
five7kid's Avatar
Did you pull the pushrod out and look at it?
Pretty weird that something like that would happen with a carb swap.
EvilCartman's Avatar
Car: '82 Z28
On that one valve, is it coming up the same height as the others? Have you checked the pushrod for damage? Pull off the rocker and take the pushrod out and shine a light down to the lifter and see if you can see anything out of the ordinary.
Old Jul 16, 2009 | 10:52 AM
92whiteta's Avatar
Engine: 355
i did take the pushrod out and it is in good shape. i looked in the hole and the lifter looks ok just sits lower than the rest. i am gonna take the lifter out and soak it in oil, maybe i can get it to pump up.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
racereese
Oct 3, 2015 03:46 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Racerx974
Sep 19, 2015 10:16 AM
