stock 1/4 mile speed
Old Jul 15, 2009 | 03:38 PM
Mattn's Avatar
i decided to see how fast i could get going in a 1/4 mile just using my speedo and odo. ive got a 305 automatic convertable. dont know what tranny or rear end. maybe you guys know?
in 400m (1/4 mile) my speedo read 140km, but i know that with my bigger wheels that works out to around 155km or 97mph does that sound about right?
Old Jul 16, 2009 | 07:03 AM
Quinny's Avatar
Re: stock 1/4 mile speed
I doubt it. 97mph equates to mid 14s - not from a stock 305 (I am assuming it is stock). From what I have found the 350 TPI 3rd Gens were the fastest, running low 15s in stock form.
Old Jul 16, 2009 | 11:31 AM
blackbetty85's Avatar
There are too many variables right now. The trans is bound to be 700R4 but the 305 ranges from 145hp in 82 to 230hp for the TPI after 89. Rear end is 2.73-3.73. The 85 Iroc w/ 215 hp and 3.42 were good for high 14s low 15s hope this helps.
Old Jul 17, 2009 | 01:37 AM
Mattn's Avatar
well its a '88 and sorry if im way off here but if it was a 700r4 that would mean there are 4 gears right? well ive never kept count but im prety sure ive got more then 4, however 1st gear is still verry agressive though. so is there anyays i can find out for sure what my tranny is?
i dont have alot of history on the car so it could verry well not be stock.
Old Jul 17, 2009 | 03:28 AM
3rdgen92maro's Avatar
Car: 1995 Firebird Formula
Transmission: Th350/4k stall
Axle/Gears: 10 bolt with 3.42s
My stock 91 Z with a L98 only got 94 in the 1/4...97 would net u low 14s
Old Jul 17, 2009 | 03:42 AM
EvilCartman's Avatar
Car: '82 Z28
700-r4 is a 4 speed trans with converter lockup, that's where you might be feeling an extra gear change.
Old Jul 20, 2009 | 07:21 PM
I forgot all about the lock up. I have an aftermarket one w/o lock up. As for the rest of your research, look at the vin. this will tell you everything about your car (assuming its stock). look towards the very front of the dash on the driver side. you will have to read it from the outside due to the 62 degree sloped windshield. Otherwise there are trans and rear end tags that will tell you what trans and what set of gears. These can only be found by getting underneath the car and the room is TIGHT around the trans. Happy hunting!
colton_carlson
Mar 8, 2019 12:21 PM
gta90
Sep 15, 2015 04:00 PM
kyleb24
Aug 15, 2015 08:24 AM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
