How to hook up HEI Dizzy?
Old Jul 16, 2009 | 08:42 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
I bought an HEI dizzy to convert from points. Do i hook up the side that says BAT to 12V with a inline fuse or no? I tried hooking it up to what my points was but im getting NO spark. Im planning to hook it up to my 12V ignition but im not sure if it will blow fuses or not.
If anything will it drain my battery if i hook it up to the battery directly (running a wire from my battery straight to the dizzy)?
Old Jul 16, 2009 | 09:06 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: How to hook up HEI Dizzy?
You want to hook it up to a good switched 12V source. Points use resistor wire, that won't work. You could use a relay. The resistor wire should close that OK and have it switch a fused 20A line from the battery to the HEI.
Old Jul 16, 2009 | 09:30 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
sweet thanks for the help
school boy
Oct 22, 2015 11:47 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Damon
Sep 26, 2015 04:29 PM
