A/C compressor is whinning. bearings going out
Old Jul 17, 2009 | 08:48 AM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
anything i can do to grease or something? the noise is so loud its drowning out the exhaust. sounds like garbage. i dont have a/c its just there until i can get/afford a a/c delete pulley or a complete v-belt set up. so is there anything i can do to help the whine temporarily? orrrr is somebody got a compressor or a delete pully for about $11.13?? its all i got in my paypal. lol
thanks in advance for any simple 'yes, you could do this..' or 'no, your screwed..' answer
Old Jul 17, 2009 | 11:02 AM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: A/C compressor is whinning. bearings going out
Do you have v-belts or a serpentine belt? If they're v-belts you can probably just get a shorter belt and simply not run the compressor. You might be able to if you a serp belt but I think your screwed if you do. I don't know if could grease anything, nothing is really "greaseable"
Alex
Old Jul 17, 2009 | 02:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Don't know if it will work, but if you are serpentine belted and still have the A.I.R. pump on, maybe if you looked at the AIR pump removal tech article, and rerouted your belt to bypass the A/C instead of the AIR pump - might need a different length belt, but it might work - see the tech article pics and description and maybe you could rig something temporarily.
Old Jul 17, 2009 | 09:59 PM
Ca[maro]88's Avatar
nahh i guess im pretty much screwed. its a serp belt. all the a.i.r stuff is gone, its just a lone compressor. ill get a delete pully. thanks guys.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
gord327
Oct 3, 2015 01:25 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
