ZZ4 & Hotcam ignition timing questions
Old Jul 18, 2009 | 08:46 PM
F-body-fan's Avatar
Hi Guys, I am doing a little research & looking for pointers before tweaking/tuning my new powerplant. I am running a ZZ4 based carbed engine with the full LT4 hotcam kit. The car seems to run strong right from the get-go, but I know there must be more to be unlocked. I am currently running a MSD igniton & distributer I have my initial timing set @ 10* with a conservative advance of 20* = 30* (good at math, aren't I)
Anyway, I have heard the ZZ4's liked to have around 10* initial & a total of around 34* Now that I am running the hotcam, I am thinking I can bump up the inital mark a bit to compensate for the poor low RPM combustion, & should be able to have my total near 34 -36* ???
Just looking to get some input from you guy that are running a simular setup so I can cut down on my test drives, & distributer adjustments
BTW, I also currently have my curve fairly quick. Its all in at 3200 RPM
Thanks, Carl
Old Jul 18, 2009 | 08:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: ZZ4 & Hotcam ignition timing questions
I'd bump it up a few more degrees and see how it likes it.
MustangBeater20
Oct 29, 2022 09:20 PM
italiano67
Dec 11, 2016 09:21 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
