Seizied Fuel Pump Push Rod???
Old Jul 23, 2009 | 01:52 PM
GI Maro's Avatar
Car: 86 Z28 Camaro
Engine: LG4 305
Hello I have an 86 305 motor that the fuel pump push rod is completey seized or suck in the block. It currentley runs off a electric fuel pump. My Problem is I want to put a cam into it and when i go to pull the cam out the journal of the cam gets jammed up against the rod. How can i get that rod out without pulling the motor out?
Old Jul 23, 2009 | 02:11 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
Re: Seizied Fuel Pump Push Rod???
Remove the mechanical FP on the side of the block and the rod should come right out.
Old Jul 23, 2009 | 02:19 PM
GI Maro's Avatar
Car: 86 Z28 Camaro
Engine: LG4 305
The rod is jammed in the block there isn't a mechanial fuel pump there any more it is just a block off plate, and the motor runs off an electric fuel pump. What i'm asking is if anyone knows how to get that rod out without pulling the motor out. I have had vise grips on it and tried to pull it out and have had no sucess.
Old Jul 23, 2009 | 04:09 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
I got a stuck one out once by rotating it with vice grips applying some heat. The engine was out of the car for that.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Reborn756
Sep 4, 2015 03:42 AM
92camaroJoe
Aug 13, 2015 06:07 AM
