est connector
Old Jul 23, 2009 | 02:37 PM
jgordon's Avatar
est connector
i have a 1984 camaro z28,i am trying to set the base timing,but i cant find the est connector.i had other people say its a brown wire,black strip,located behind brake booster,passenger side firewall,i even heard its a 4 wire connector.i m having no luck finding it.i just set the timing without unhooking anything,to 10 degrees btdc.would that be about right?
Old Jul 23, 2009 | 03:07 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: est connector
It comes out the passenger side fender, open up your wire loom and find it, it should be the only one inside the loom with a connector (Yes brown and black striped wire). Mine stuck out from the loom, that's how I found mine.
Some sit right on the AC Box against the firewall, some sit clockwise around the strut tower, some sit flush with the fender line. Those are all the places I have seen them, never by the brake booster though....and never a 4 wire connector.
Maybe years factor in this? I know for a fact though my buddies 85 TA, my brothers 86 berlinetta, my other buddies 87 maro and my 89 maro all had it in the exact same spot.
Old Jul 23, 2009 | 03:17 PM
jgordon's Avatar
Re: est connector
thanks for the quick reply,iam going out right now to check for that wire.but if i cant find it,would 10 degrees btdc be about right without unhooking the wire?
Old Jul 23, 2009 | 06:30 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: est connector
On an '84 you disconnect the 4-wire computer connector at the distributor. The timing set directions are on the emissions decal on the radiator support. Base timing should be 6 degrees BTDC.
Old Jul 23, 2009 | 06:39 PM
jgordon's Avatar
Re: est connector
i disconnected the 4 wire connector at the base of distributer and set the timing,pluged 4 wire connector back in,checked the timing again,and the mark is at the same place?when i connected the 4 wire connector after setting the base timing the timing shoud be around 20 degrees btdc right?
Old Jul 26, 2009 | 12:46 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: est connector
my 86 IROC-Z EST connector is here on my picture below.
Old Jul 26, 2009 | 10:19 AM
jgordon's Avatar
Re: est connector
found the connector coming out of distibutor,set my base timing,pluged est back in,then checked timing with est connected,the timing is still at the same spot,that is not right,right?
Old Jul 26, 2009 | 05:08 PM
Re: est connector
try setting the timing in this manner here https://www.thirdgen.org/settingtiming
Old Jul 26, 2009 | 05:20 PM
jgordon's Avatar
Re: est connector
i set the timing the way it says but when im all done after pluging the est connector back in the timing mark is still at the same spot.with the est pluged back in shoudnt the mark be further advanced?
Old Jul 26, 2009 | 05:28 PM
Re: est connector
good question. . Try this, highlight and copy the hyperlink and post it in other forums such as electronics and TPI sections. That way someone who has more experience with timing can stumble accross your thread and hopefully get you some answers. Thats how im getting answers. Do you know how to copy and paste a hyperlink?
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
