bad hesitation on hard acceleration?
Old Jul 30, 2009 | 11:39 PM
aciddrop2804's Avatar
Car: 1984 camaro Z28
Engine: 5.0L H.O. L69
when ever i try to go wot, there is about a 4 second delay before it finally kicks in and even then it seems like its not going very hard. do you think a tune up could help fix this(ie spark plugs, wires, distibutor cap, rotor, coil) or something else maybe? thanks.
Old Aug 1, 2009 | 09:05 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: bad hesitation on hard acceleration?
It could possably help but my best guess at this point is a vacuum leak. Might wanna pull a few plugs i suspect thell be on the white side.
Old Aug 1, 2009 | 03:17 PM
ok. well i pulled one and it was covered in a thin coat of carbon(black) so i dont think thats the problem.
Old Aug 1, 2009 | 04:10 PM
Well then the next thing ide check is your timing
Old May 12, 2016 | 04:55 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
What was the cause
Old May 12, 2016 | 10:01 PM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
Change your spark plugs. Mine did a similar thing because all of the plugs were starting to foul.
Prodigious
Nov 7, 2020 09:23 AM
db057
Sep 4, 2015 07:57 AM
someone972
Aug 30, 2015 12:52 AM
db057
Aug 22, 2015 08:17 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
