Power Steering pulley installation tool
Old Aug 1, 2009 | 11:30 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Hey Fellas. I was hoping that maby one of you has knowledge of the power steering pulleyremoval/installation tool. My question is, What is the size of the smaller threaded end that screws into the shaft of the power steering pump? I need to know the size so that I can buy just a bolt instead of the tool itself to save me some money. Thanks guyz .
Old Aug 2, 2009 | 09:05 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Power Steering pulley installation tool
It is a 3/8 x 16 NC thread. May need to clean the dirt out first, seems to build up in the internal threaded end of the shaft.
Can use a light coat of oil on the ID of the pulley to help out.
RBob.
Old Aug 2, 2009 | 12:45 PM
Nice. RBob. One more thing, what does NC stand for?
Old Aug 2, 2009 | 12:48 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
If it's just a one time thing, you may be able to rent them for free from a local parts store. That's what I do.
Old Aug 2, 2009 | 01:00 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
NC = National Coarse. Which in this case redundant as the -16 thread already specifies that.
If the thread was 3/8-24 then if would be NF, National Fine.
There is also a NSF spec, National Special Fine. I think for 3/8" it is 27 threads per inch.
RBob.
Old Aug 2, 2009 | 01:15 PM
Gotcha. I didnt know that. I knew it only as fine thread or coarse thread. Thanks bro. Peace
Old Aug 2, 2009 | 01:18 PM
I already called Autozone, not in inventory; PepeBoys the same, Napa nothing, Car Quest nothing and where im from, Imperial Valley CA. there is no Advanced Auto Parts store. Unbelievable huh.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
TheExaminer
Aug 25, 2015 07:34 PM
Navy8125
Aug 22, 2015 07:13 PM
