power steering whine
Old Aug 3, 2009 | 08:57 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
so my 86 silverado is making a horrible whine from the belt slipping on the pump pully. ive swapped the pump already and its still slipping. what else could be causing it. and i know this isnt about a 3rd gen but theres nothing wrong with my camaro at the moment and this noise is driving me insane.
Old Aug 5, 2009 | 06:03 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: power steering whine
I know you said you had replaced the pump, but what about the pulley or belt? If the belt is glazed, pulley's warped, or pulley's not correctly aligned with the rest of the accessory pulleys, that could be your issue.
Old Aug 5, 2009 | 08:08 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
I concur with 1A Dan. Replace the belt (never a bad idea). Check belt/pulley alignment. if anything isn't true then you are going to have noise. I have never had a bent pulley make a noise, but it could.
Old Aug 6, 2009 | 07:18 AM
travis401's Avatar
Car: 91 Camaro RS
I replaced the pump and pulley at the same time, the belt looked good to me but ill try replacing it today after work. I thought it might be the steering box or maybe air trapped somewhere in the system or maybe even the fluid. But I don't know much about powersteering to tell.
Old Aug 6, 2009 | 04:22 PM
travis401's Avatar
Car: 91 Camaro RS
forgot to mention it only makes the squeal when turning.
Old Aug 16, 2009 | 09:22 PM
travis401's Avatar
Car: 91 Camaro RS
just to let u guys no, it was a stretched belt. i replaced it and now it only whines a lil bit at startup.
Old Aug 16, 2009 | 10:13 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
recheck your fluid levels - using the pump will settle the fluid into the system, and now it might be low.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
