tranny mount problem
Old Aug 16, 2009 | 01:22 AM
805camaro805's Avatar
Car: 91 Rs Camaro
Engine: 305 tbi
Transmission: 700 r4
I break my transmission mount about every 3 weeks. Would a metal one be better than the 2 peice that i currently have on? Also which one.
Old Aug 16, 2009 | 01:45 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: tranny mount problem
Are you using rubber or poly? I can't imagine poly breaking like that. I have a 350, shift kit, vette servos, and when my tranny shifts from 1 to 2, it jerks your head EVERY time, and barks rubber EVERY time, regardless of how light you are on the pedal, and my poly mount is going on 3 years old now.
Old Aug 16, 2009 | 02:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
do not use metal, it will damage the trans.
use poly if you need something stronger. I would go with prothane, i broke a energy suspension one with hardly any mileage on it. Prothane seems to be made better as well
however, is the car still stock? there is no reason to go through mounts that fast. Are you sure you dont have a broken motor mount that is letting the drivetrain move too much and causing the trans mount to fail?
Old Aug 16, 2009 | 04:08 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
i snaped 3 rubber trans mounts after i put my shift kit in all with in 2 weeks.. ive had a poly mount from energy suspension and have had it for 2 years now and have beat it and beat it and its with held my abuse.. i also have poly motor mounts to go with it.. what a difference
Old Aug 16, 2009 | 10:23 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
My energy suspension poly mount deals with the stress of my T56 with no problems. Just go poly. Those rubber ones suck.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
hokis
Aug 9, 2015 03:57 PM
