New Heads on a high miles SBC
Old Aug 6, 2009 | 09:55 AM
RedHawkLB9's Avatar
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
hey guys..im thinkin about gettin some new heads for my sbc...but its got alotta miles on it..and i heard bad things if i was to swap out the heads for some new alum ones..But is it true that i could blow up the bottem end?..its got 171k..but runs very solid
thx guys
Old Aug 6, 2009 | 12:02 PM
Jaydog143's Avatar
Car: 1989 Iroc-z
Engine: 5.7L 350
Axle/Gears: Stock 2.77 posi
Re: New Heads on a high miles SBC
Just clean ur deck really good, Honestly, you should have it machined but you can get away with just cleaning it real good.
Dont see how aluminum heads will blow up your bottom end??? Are they small chamber heads? Just dont buy heads that will make anymore than 11to1 compression otherwise your motor will ping unless you run race gas in it.
Get a head in the 64cc range, Witch if your car is a l98 it should have iron 083 64cc heads allready on it. But an aftermarket set of afr 190's will wake it up like no other!!!
Old Aug 6, 2009 | 01:04 PM
StringRust's Avatar
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
What engine are the heads for. Im assuming you have a 305 LB9?
Old Aug 6, 2009 | 01:31 PM
RedHawkLB9's Avatar
Car: 89 Formy
Transmission: A4
thanks for the reply guys!....but yeah..i have lb9 305..and the stock heads need valve guide's to be done...but i rather throw in a nice size cam and set of the trick flow 56cc alum heads on there...so u guys think it will be fine along as i clean up the surface area were the heads sit(pistons etc)
Old Aug 6, 2009 | 01:54 PM
Jaydog143's Avatar
Car: 1989 Iroc-z
Engine: 5.7L 350
Why does your avatar say tpi then??????????????
Old Aug 6, 2009 | 02:29 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
The LB9 is a TPI motor. It's a 305 TPI.
Old Aug 6, 2009 | 02:48 PM
Jaydog143's Avatar
Car: 1989 Iroc-z
Engine: 5.7L 350
My bad man, never had a 305 so I never new the actual name.
I personaly would not waste my money on a 305......but thats just me. 350 blockes are a dime a dozen and cheeeeep as crap, I mean really, you could spend a 1000 dollars on a set of heads and everything that comes along with it, or you could spend 300 dollars on a 350 block and be further ahead??? If my understanding is correct the tpi unit is the exact same for the 305 just smaller injecters, and some computer tuning....
But the heads your wanting to run will definetly wake it up thats for sure, wont hurt the bottom end at all.......unless you spray, or wing it up to 8000 rpms all day long.
Old Aug 6, 2009 | 06:37 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Do a compression check on all cylinders first. If they test good, change the heads, cam, and timing gear set together. Your pistons will be covered with carbon so clean them off while you're in there.
Old Aug 6, 2009 | 06:57 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I would not worry about blowing up the bottom end. If you raise the compression there might be some more blowby and therefore higher oil comsumption. But then again there may not be any.
CRFred
Feb 7, 2016 11:39 PM
gta90
Sep 15, 2015 04:00 PM
BBSDesigns
Aug 11, 2015 07:39 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
