Air only comes out of vents at low RPM
Old Aug 6, 2009 | 06:35 PM
gulf_coast_228's Avatar
Car: 1992 Firebird Trans Am GTA
I'm having trouble on where to start looking for this problem. Friday on my way home from work as I accelerated air stopped coming from the vents and instead started coming out the floor and defrost vents. When I slowed down (of course the RPMs going down) the air started coming back out the vents again. When I sped up (RPMs going up) the air stopped and again out the defrost and floor vents.
I'm pretty sure I have a vacuum problem, but doesn't this normally work the other way around? On another car I used to own (92 Grand Prix) air would only come out of the vents when the RPMs were high, which makes sense since there would be more vacuum.
Today it started to do that again but after a while corrected itself and stayed normal the rest of the drive.
Any ideas on what's going on?
Thanks for any advice. This site has been an invaluable resource and I've solved many issues I've had with my firebird with a simple search here. I can't express how awesome this site and the community are.
Old Aug 6, 2009 | 06:59 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Air only comes out of vents at low RPM
Remember the highest vacuum is at idle. As you open the throttle the vacuum declines. So yes you are losing vacuum somewhere.
Old Aug 10, 2009 | 10:33 AM
Thanks for clarifying man. I'm thinking it's at the switch since I can hear a hissing noise from it. Figures this would happen in the heat of summer.
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Jake_92RS
Aug 17, 2015 09:42 AM
perZ
Aug 15, 2015 01:17 PM
mustangman65_79
Aug 11, 2015 03:17 PM
