rebuilt 350 tbi burning oil...running like Sh$t
Old Aug 7, 2009 | 06:05 PM
robbyho21's Avatar
Car: 88 camaro
Engine: 355
Transmission: rebuilt 700-R4
it an 88 tbi 350 rebuilt less than 10k ago, new pistons ring and valve job. it started burning oil after 3-5k and before i pulled the engine it barely ran. i took the engine apart and the 4 and 8 piston top and valves has alot of crud built up on them but everyone else is clean and normal. what would cause this rings? valve seals? head gasket? it used about a quart every few weeks and was running on 6 cylinders. any ideas. thanks
Old Aug 7, 2009 | 08:17 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Re: rebuilt 350 tbi burning oil...running like Sh$t
Could be a few things, you should have first checked your compression. But now try these,
check your heads and look at the exhaust valve and intake valves are they both "coked" up in the runner?
does the intake lifters rise the same amount as the other lifters?
use a valve spring compressor and remove the intake and exhaust springs and check for excessive play/bad valve seals.
thats all i can think of right now someone else might be able to tell u something else to check.
Thanks, Chas
Old Aug 7, 2009 | 09:17 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Sounds like the block and pistons need to go to a machine shop to have them checked. May have excessive piston to cylinder wall clearance.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
backtothe80s
Sep 5, 2015 12:39 AM
crazynights
Aug 21, 2015 06:53 AM
