Vortec Head Mahine Work
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Sorry i spelled machine wrong in the title... anyway
I am looking to get some more out of my vortec 350 setup. It currently is a TBI motor putting out around 310 hp. I am wanting to go carb, new cam, intake, and get some head work done to my GMPP iron Vortec's. My question is what needs to be done to clear a larger cam with the heads? What price does this usually run at the local machine shop?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Vortec Head Mahine Work
For an intake, I'd say the Edelbrock RPM Air-Gap intake and a Q-jet carb. the intake is a high rise intake though so I'm not sure if that fits under the stock hood. Might be able to make it fit with a drop base air cleaner. Otherwise the Edelbrock Performer is a decent upgrade from stock. Like I said earlier, I like Qjets but lots of people like holly's. The choise is really yours. You can get about the same power out of each of them though the Qjet will have slightly better economy. By going carb I am going to assume you don't need to worry about emissions where you are so I won't go into that.
Car: 1986 Irocz
Axle/Gears: 3.25:1
Common mods for a larger cam are getting the tops of the valve-guides and guide bosses cut down, and sometimes machining of the valvespring pockets - depending on your choice for valvesprings. A better spring might require a larger diameter pocket, or a deeper pocket for more intalled height.
If your guides are worn, then it would be a good time to get them resleeved.
Other mods depends on the shape your heads are in and what gear they have on them now. It's usually a good idea to freshen up the valve-job.
One option if your guides are worn and you will need a valve-job is to convert the heads to 8mm valves (8mm sleeves/liners) and upgrade to stock LS1 valves which are lighter and flow better. You can then use Z06 beehive style springs which go for about $50 on ebay and fit in the stock spring pockets. You can use stock LS1 retainers which are lighter and smaller, giving more clearance for higher valve lifts.
Another performance gain can be had by pocket porting your heads to better match the larger LS1 valves.
Car: 92RS
Engine: LQ4
Transmission: 4L80E
thanks for the great info. my question now is are the iron vortec heads worth getting machine work done? Realistically, what kind of hp numbers can you see out of them with minor head work done and a larger cam?
Car: 92RS
Engine: LQ4
Transmission: 4L80E
im right around 310-320 right now. I was looking to get around 400 out of it after doing the cam, intake, carb conversion.
if you go to comp cams website you can download a program called cam quest that will help you choose a cam or you can call there tech line. for my engine i called there tech line and told them i wanted 450hp and 500tq they gave there suggestion they where with in 5 hp and 10 tq on the dyno
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Car: 1987 Camaro Iroc-Z
Engine: 5.7L 350 TPI
Transmission: Manual Valve body TH 350
well ive been bouncing around on threads trying to figure out if i should go carbed or tpi with my vortec setup. after reading people with high flow bases cams heads and more barely turning 300hp it makes me pretty sad but reading the numbers and the amount of money they had to put into that carcraft link build i think i got something growing in my pants lol. im deffinately going carbed i dont care what kind of gas hog/O-zone destroyer ill be running 400 horses would be a good place to start ty for the link.
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
