HELP PLEASE! Timing jumps after being set with timing light! Causing Overheating!
Old Aug 11, 2009 | 10:28 AM
91RS84TA's Avatar
Car: 1991 Camaro RS/ 1984 Trans Am
Engine: 305 V8 TBI - 350 Swap In progress!!
Transmission: 700-R4
Axle/Gears: STOCK
Okay so I did a 305 to 350 Swap (Rebuild from 73' chevelle)on 1991 RS, and were hopefully wraping up the swap. PROBLEM!!! My mechanic keeps setting the proper timing to the car but he says it keeps jumping after being set on its own. We did new plugs, correct firing order with new wires (Accell), and lined up everything with first spark plug and everything. He sets it using the timing light and then it will jump from i believe he said 12 degrees to 20 degrees. Don't quote me on that because im not sure of the exact numbers. Installed a new fan and thermostat yesterday, still climbs to 220 degrees. The coolant is flowing but the reservoir looked like a guyser after driving it for 5 minutes very easy. Maybe my distributor from the 305? Or my module? Maybe both? Help PLease?
-Long tube headers
-Flowmaster American Thunder 3" setup
-Still using the original TBI from the 305.
Old Aug 11, 2009 | 10:46 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: HELP PLEASE! Timing jumps after being set with timing light! Causing Overheating!
Do you know that you have to disconnect ECM timing control when setting initial timing with a light?
Old Aug 11, 2009 | 11:23 AM
91RS84TA's Avatar
Axle/Gears: STOCK
No I didn't know, How do you do that? Thanks for the help!
Old Aug 11, 2009 | 12:10 PM
mnorton's Avatar
Engine: 305 LB9 TPI
The is a brown wire under the hood, near the firewall, on the passenger side. Un-plug the connector to disengage ECM timing control. Set the timing to 6 deg. then reconnect the wire.
Old Aug 11, 2009 | 05:54 PM
danandamy's Avatar
Car: 86 Camaro
Hmmmmm hate to say it but coolant gushing from the reservoir sounds like compression getting into the cooling system.
Dan
Old Aug 11, 2009 | 05:59 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Dan
if your only hitting 220 deg....it shoudn't be 'gushing'.....that's not much past were the factory runs them....what temp thermostadt did you put in?? what kind of fan do you have? eletric/mechanical? you shouldn't be overheating at 220....pressure in cooling system due to failed head gasket probably
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
Omega
Aug 10, 2015 12:46 PM
