Gauge swap questions?
Car: 85 Firebird & Grand Prix GXP
Engine: LG4 305 (originally 2.8L V6)
Axle/Gears: 10 bolt 3:43 Open Diff.
I couldn't find my answer when searching so I'm posting here. My car is a 1985 base Firebird that came with a V6 that's been swapped to an '87 LG4 305 by a previous owner. I've got the gauge cluster with no tach and the dummy lights currently.
I just bought a new gauge 120 mph cluster with tach, oil pressure, temp, etc. that was from a '92 Firebird and want to install it. Before I tear apart my dash I need to know if it's goig to work of what I need to do? I've put pics of the new gauge cluster below.
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Gauge swap questions?
Im pretty sure it wont work if for no other reason than the speedometer 92 was an electronic speedometer sender where as the 87 lg4 set up would have been a mechanical sender if im not mistaken.
So would I just need to find an older Trans Am dash with a mechanical speedometer?
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
you shuld need a mechanical dash, yes
What year did this change from mechanical to electric?
Ghettobird52
Jul 5, 2024 11:18 PM
