accessory bracket help
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
TBI car now carbed. I'm deleting A/C - already deleted AIR. And I hate the stock brackets and the idea of the A/C delete pulley - I want a simple oldschool look. I'd like to move alternator to pass side, BUT keep serpentine belts.
1) Can I use brackets such as these to mount an alternator on pass side and remount P/S pump (to get rid of that bulky bracket)?
Alternator: http://cgi.ebay.com/ebaymotors/BILLE...Q5fAccessories
P/S Pump: http://cgi.ebay.com/ebaymotors/ALUMI...Q5fAccessories
2)Will this belt routing work? (the blue dot is the new/moved alternator, and I'm assuming I'll have to change from a reverse to a standard water pump)
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: accessory bracket help
you may still need a tensioner. you also don't have much of the belt touching the crank pulley...you may have a slippage problem
Car: 1992 RS
Engine: Carbed 350
The alternator bracket does the tensionng with the adjustable turnbuckle that comes with it.
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
These brackets are usually universal but check these places before and see what you can do as far as research between the ebay ones and these companies kits.
www.billetspecialties.com
http://www.billetspecialties.com/subcategory.asp?cid=4
www.marchperf.com
http://www.marchperf.com/csb_brackets.html
www.marchperf.com
