how to change motor mounts?
Old Aug 15, 2009 | 01:43 PM
littlesk8cracke's Avatar
hi guys, we got the motor out of my dads 84 z28 for rebuild, and im changing the motor mounts (the ones with rubber that attatch to the crossmember). we got the drivers side off, but cant get a wrench up in the passenger side. whats the easiest way to get this one out? does the a-arm have to be removed? and if so, can you get the spring back in with the engine out? someone once told me you cant put springs in with the engine out cause theres not enough weight on the front of the car? thanks
Old Aug 15, 2009 | 03:18 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: how to change motor mounts?
It can do it without pulling the A-arm. You need a long 15 mm combination wrench that you can bend the angle on the box end more to match the nut.
Also use flange nuts when you put the mounts back in, as they will stay in the wrench when you go to start the bolt back in them.
If you need a picture of the wrench, lemme know.
Frozer!!!
Jan 19, 2024 04:55 PM
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
