What to do for Fall-Winter Project Any sugesstions...
Old Aug 16, 2009 | 08:16 PM
acerocks666's Avatar
Car: 83' Z28 camaro
Engine: 5.7L 350
Transmission: TH350
Hey guys thinking about what all to do in a fall-winter project on my 83 z28. I am for sure gonna be pulling the motor and tranny so I can clean up the engine bay plus I think my tranny is going bad (th350). Just want some suggestions on what I can do with the motor (5.7L 350) why it is out of the car. So some questions are:
1. With the tranny now it just seems to have trouble shifting especially into reverse if anything at all but I am probably just gonna go with a brand new th350 which right now I am thing about the TCI 311098 from summit or is there something better for around that price range?
2. The engine itself when I bought the car 4 years ago I didn't really know to much about the 350 in the car as I was buying primarily for the body and everything else anyway. The engine seems to run just fine no leaks that I can really see except for an exhaust leak on passenger side but other then that I think everything is still good but won't know for sure until I pull her out. In any case If the engine is still good as in block, heads, crank, and so on what are some things I should do other then my headers while I have it out. Can I just do a good $250 rebuild kit on it and be done?
3. I have a good buddy of mine who knows a heck of alot more about engines then me that I am gonna have help me look at it and if he thinks it needs a rebuild should I go ahead and do it or just drop in a new crate 350?
Keep in mind with these ?'s that I am not looking at making an extreme amount of HP here. This car is my please car during the summer and is just for regular driving and I would like to keep as much fuel economy as I can.
Money is not really a huge issue but I would like to stay on the budget side and still get good parts...
Any suggestions are appreciated!!!!
Old Aug 16, 2009 | 09:50 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: What to do for Fall-Winter Project Any sugesstions...
If want good mileage than I'd suggest getting a 700r4 tranny or T56 if you like. The over-drive will help a lot on highway driving.
For the motor, do you know what vintage it is? The mid-late 70's 350s really suck. The stock 350 in my 74 Nova only came with 135hp, that's just as much as the 2.8 in my Maro. If so then get a crate, if it's newer than you should probably just rebuild it, slap some headers and a nice cat-back on and I think you'll be happy.
Good luck
Alex
Old Aug 16, 2009 | 10:02 PM
thelast_graham's Avatar
Car: 1984 Chevy K5 Blazer
Engine: SD TPI 350 w/FIC Bosch IIIs
Transmission: 700R4 4X4
Axle/Gears: 3.08 front and rear w/ 33" AT tires
I agree the novafirebirdguy... Def a 700R4 with a semi shift kit..
upgrade to a newer TPI motor and fixer up man!
Maybe... Change to a 4L60E or 80E with an LT1 with LT4 parts!
Old Aug 17, 2009 | 12:37 AM
Car: 83' Z28 camaro
Engine: 5.7L 350
Transmission: TH350
Well I am guessing that the engine is around the 83 year of the car but am not for sure. So if it is an early 350 I should just go for the crate I guess I am still looking for some power just not anything huge with still decent mileage...
Old Aug 17, 2009 | 08:58 AM
Then I'd say get the 290hp crate 350 that you can pickup for $1800. And for the tranny, if you can find one with corvette servos and a shift kit, it makes a BIG difference. Much crisper, better shifts.
Alex
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
Vincent135
Sep 28, 2015 10:50 PM
