new motor what balancer?
Old Aug 19, 2009 | 01:21 PM
Colts45s's Avatar
Car: 92 camaro rs
Engine: 350 tbi/416's/comp xe268
Im about to drop in a 350 stroked to a 383 that was taken out of a chevy pickup. the problem is that the engine does not have a balancer. Do i use the balancer for the truck it came out of or do i just match it to my 92 305 tbi balancer or should i use a z28 350 balancer?
Old Aug 19, 2009 | 04:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Depends on how the crank was balanced.
If internally balanced, you can use any of those dampers.
If externally balanced, you need a weighted damper.
Old Aug 19, 2009 | 06:13 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: new motor what balancer?
five7 pretty much summed it up short and sweet. 305s and 350s are internally balanced. 383 quite often use externally balanced flywheel and balancer setups (like found on the SBC 400s in the 70s), but that can depend on how it was built.
Definitely don't want to use the wrong one here; My 400 crank was destroyed when the previous owner thought it was ok to use the flywheel off his 350...
Old Aug 19, 2009 | 08:54 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
if it's a cast crank more than likely it is externally balanced unless it has 6" rods. 95% of forged cranks were internally balanced on 383's.
Old Aug 19, 2009 | 10:34 PM
Colts45s's Avatar
Car: 92 camaro rs
The crank is internally balanced. I guess my real question is that,"Are the timing indicators on the balancer the same?"
Old Aug 20, 2009 | 01:07 PM
five7kid's Avatar
Depends upon which timing tab it was marked for.
Is the zero mark close to aligning with the keyway slot? Then it's marked for a 2 o'clock tab (actually closer to 1:30).
Is the zero mark significantly counterclockwise from the keyway slot? Then it's marked for a 12 o'clock tab.
italiano67
Dec 11, 2016 09:21 AM
hydrolic144
Sep 8, 2015 06:55 PM
gixxer92
Sep 1, 2015 04:32 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
