Ignition Switch problem
Old Aug 23, 2009 | 05:22 AM
kenong's Avatar
Car: 91 Camaro Z28, 1LE, G92
Transmission: 400R7
Axle/Gears: 3.48
Hi.. I have a '91 Z28 G92/1LE.. The ignition switch, 1 out of 4 times will not rotate to the position where U can remove the key or past that point to the Acc. position.. If I wiggle the barrel around enough in the column, it will finally allow movement to that position & allow removal of the key. My mechanic says it's not the shift lockout cable... The barrel does have a lot of slop in the column...
Can the barrel be changed? Will a new VATS key comre with a new barrel? Is this a common problem on cars this old?...... Thanks .. Ken, Tampa FL
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
djmarch
Aug 9, 2015 05:27 PM
