How much hp?
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Axle/Gears: Borg warner 3.08's
How much hp?
Im buying a fresh from top to bottom 355 chevy engine. Camel back heads, 1.94 int & 1.50 exh.....comp cam 286 dur 490-490 lift...comp valve springs and lifters....1.6 crane roller rockers... .30 over flat top pistons...double roller timing chain & gear...steel crank...weiand 8400 dual plane intake...high volume oil pump...6qt oil pan...all new molly rings-bearings...freeze plugs..etc. How much hp and torque will this engine produce?
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Re: How much hp?
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Re: How much hp?
The heads have been ported. He told me the compress would be eather 10:1 or 11:1 but was not sure. He said it will produce between 375hp and 400hp.
Engine: 400
Re: How much hp?
It's always hard to tell unless it has been a really reputable guy doing the port job. I can go out in the garage with the dremel tool, hack some metal off my heads and they are 'ported'. But well? Probably not.
I'd just be happy if the motor runs strong. You can always opt to a set of aftermarket heads when the time and money is feasible.
