79 350 changed over to tpi! need help!!!! Pics attached...
Old Aug 24, 2009 | 08:32 PM
spun350's Avatar
Would appreciate any help with distributor question... Have concerns in regards to using newer style distributor from '91 motor in the '79 motor. Somewhere in a post I read that the gears would not interchange as far as meshing with the cam gear. Tried to remove gear from older type vacuum advanced HEI distributor & relocate it to the new distributor, but shaft sizes are different. The HEI vacuum distributor shaft is larger than the '91 distributor shaft - WAY too much play... not even close! Is there anything else that I should be concerned about in this area? If there is a gear that I need to get, can someone please provide a number? Any thoughts on how the motor will act with the tpi set up? Motor is punched 30 over. Did not have any lope at all. Had heads sent off, valve seats & valve springs re-done, new gaskets, cam was checked, re-used old lifters & push rods & re-assembled. Had to modify the 4 center bolts on intake so it would bolt up as required.
All questions, comments, suggestions welcome!
THANKS!
Old Aug 24, 2009 | 08:39 PM
spun350's Avatar
Re: 79 350 changed over to tpi! need help!!!! OOPS! Here's the pics
Didn't get them attached the first time... Sorry...
Attached Thumbnails 79 350 changed over to tpi! need help!!!! Pics attached...-m-350-003.jpg   79 350 changed over to tpi! need help!!!! Pics attached...-m-350-004.jpg   79 350 changed over to tpi! need help!!!! Pics attached...-m-350-006.jpg
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
